Ok this may take awhile and I may not explain everything correctly so bare with me. I took my lower end in a mechanic to put knew seals in and transfer parts from the middle lower unit into another one (not the actaul gear case the one above it). He put it together saying he could not get all seals but would manufacture some of his own, I believe he used neoprene. Anyway he gave it to me and said it was done. I put it back on the ,motor put it in the water and discovered it would not go into gear. I pulled it back out dropped the unit and seperated the lower unit and discovered he had the wire for the forward gear crushed between the 2 units and almost severed it. Since I was upnorth and did not have all tools with me(extra wire) I put electrical tape around it. Also when I was in there I had to drain the oil and put knew type "C" and saw that it had water in it. So refilled with oil and put back together. Put in water and gears started to work. First 10 minutes it was going great then it would not go at full speed. I would put in full throttle but and would hesitate like it wanted to but would not. It purrs in nuetral, but will not go hard in full launch. Like I said it kind of jumps like it wants to go. It also somehow drained my battery. My question is would the wire I taped still be arching? Is this why I am not getting full power and draing my battery. I will be going back to the mechanic either way. Any help would be great. The motor is a 1963 Johnson Electromatic 75hp.
