Re: Lower end water leak 35 evin
Murray44,<br />I don't think you have a problem! As Hondon said, water comes out of lot's of places when you have the ears on a motor, especially if the motor is not running. There is no gasket between the lower unit and the leg. As long as water is coming from the tell tail with the motor running you should be OK.
