lower control gears not resonding to the main throtle control commands
monkey99
The problem that I'm having is the gear shifter located on the lower section of the out broad motor is not responding to the command given at the main throttle control located on deck. I also noticed that when I'm trying to change from neutral, drive ,and reverse the throttle button gets jammed and won't allow the conversion. If the boat does go into drive or reverse it kills before converting back. The only thing I had done was change out the impeller, which after being reinstalled had the gear stuck in drive. I then pulled the lower portion of the outboard motor back down, reinstalled, and it is now struck in neutral. I have checked gear oils which were low but have been topped off. Nevertheless I'm at a lost, yet feels that I'm close to the solution. Any ideas or advice......?
tx1961whaler
Re: lower control gears not resonding to the main throtle control commands
What kind of motor are we talking about?
NYBo
Yes, we need to know what motor you have.
You apparently didn't reconnect the shift rod correctly when reinstalling the lower unit.
5150abf
Pop the hood off and watch the shift linckage on the engine and see if it moves with the shifter, it does sound like you didn't get something hooked back up.
Did you turn the or remove the shift rod when you had the lower dropped?
