low rpm
SamLin
my 1987 bayliner at wot will only get up to 3500 rmp and will not get boat up on plane . when not under load the rpms will go up to 5000 . boat has ne fuel pump filter carburator and has had the ignition changed to electronic ignition . any ideas as to what my problem is. please help
isimar
have you checked the exhaust port to make sure it's not plugging up ? had that happen to the motor on my pontoon.
smokeonthewater
Test compression and ign timing on engine.... Also make sure that the throttle actually opens fully when you advance the lever all the way ( check with engine OFF).....
As mentioned above what prop? Pitch? Condition?
