Low rpm on 2007 25hp Merc EFI
toasted tomato
I can only get about 3000 rpm on full throttle. I used to be able to get about 6000 rpm. Don't know if it's connected but I hit a rock and bent the prop shaft so I have replaced it and the prop. I think I got the same pitch prop. When I look at the linkage travel inside the motor, it appears to go all the way forward. I have replace the 3 plugs. Any ideas why the motor might be rpm limited? Thanks for your help.
