Well I finally got my '77 850 to start. At idle speed I'm hearing some knocking. It doesn't sound like a metal-to-metal "tink" but more of a "donk" or "clank". However, when I increase throttle from high idle, the sound seems to go away. What's the easiest way to diagnose this problem? If I remove the manifold will I be able to check the rods and crank or do I have to get in deeper? This was out of the water, so could I just be hearing exhaust cobwebs from this old motor? Compression test gave me 110, 115, 90, and 90.
