low oil warning
midnyte
I drive a Mack truck for a living and if the oil press. or wter level is low it will shut the engine down. I wonder if my low oil warning going off on my 2007 merc. Optimax is causing my engine to shut down when WOT. (over 4000 rpm)
Faztbullet
Why use it if it has a oil warning??? Depending on hp it has Guardian mode which will reduce rpm but not shut it off. It may be seizing from lack of oil if its completely shutting down...
midnyte
Low oil sensor
Are these the wires for the low oil sensor. If they are I unplugged them and still got a 4 beep every 2 mins. warning tone. Does that mean sensor is good and the problem is the water in the fuel sensor. If so where is the water in gas sensor loacated. Thx much George
Fun Times
Hi there, welcome to iboats!:)
To help keep everything in perspective, I've merged your two topics together.
By chance what engine size/model do you have there?
To help find some detailed information about your engine, do you have your engine serial number handy?
Fun Times
The latest service manual for your engine is Mercury part number 90-8M0047659... The original part number started off as 90-889785 back in 2004. If you plan to do your own work, it would be highly recommended to purchases a manual. If you run the part numbers online, you might be able to find a good deal on one. The correct service manual for your engine does not seem to be available online for free.
Here's your parts catalog for your engine model.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=891837007
As a general guide, this should help you troubleshoot your engine mounted oil reservoir.
http://www.boatinfo.no/lib/mercury/manuals/115-135-150-175_optimax.html#/268
You should be able to find two wires (possibly blue with black stripe in color) coming off of the engine mounted oil reservoir. You should also have a oil tank located in the boat.
If anyone one of them are low on oil (< or thinks it's low), has a cracked or loose fitting cap, damaged seal/gasket under the oil cap, out of ohm's range on the sensor/switch, chaffed wire to ground, air in the oil reservoir or system (< most typical due to bad cap), then yes that could sound 4 beeps per minute warning horn or depending on severity at higher RPM, it could go to a constant alarm plus activate guardian mode which could bring the engine all the way to idle. It's not supposed to kill the engine, but it's possible that the engine could get so low on idle that it may die on you.
On average, anyone of the items mentioned that could be wrong has a tendency to go bad do to being mishandled during servicing.
The fuel system water sensor is located at the VST fuel tank (Vapor Separator Tank Assembly) Item number 30, http://www.mercruiserparts.com/Show...png&inbr=13052&bnbr=170&bdesc=Vapor+Separator
Let us know what you find, good luck.:)
