Low Oil Pressure Alarm
bvlmv
Hi,
I' recently gave my 5.0Gi PWTR it's first oil change and used the VP recommended grade SAE 30 (PENNZOIL BRAND). For the first time this past weekend I got a low oil pressure alarm while idling to the sandbar and back to the dock. This didn't happen while going at high speeds. I did verify the correct oil amount and my bilge was clean when I docked.
I haven't been able to replicate this while running on muffs so putting a mechanical gauge is not going to help much now.
Just curious, being that my engine is a 99 could the oil grade have caused this? Should I
Thanks!
Don S
Re: Low Oil Pressure Alarm
How do you know it was low oil pressure and not a high engine temp alarm?
What did the gauges show during the alarm?
No, the type or grade of the oil is not the problem.
bvlmv
The oil pressure needle what hitting the low red marker while the alarm was going off. The temp gauge was between 1/2 to 3/4 of the way up.
Don S
Your low oil pressure switch and the oil pressure sender are two different units, and not connected in any way.
I would say you do have an oil pressure problem of some sort.
Since you just changed oil, and assume you replaced the filter too, I would replace that filter again, it may be defective and causing the problem.
bvlmv
Got it. I'll work on that this weekend.
Thanks again Don.
bvlmv
Hi Don,
Just a quick update on this issue. I started the engine up today to see if I can replicate the issue and sure enough on the first try the oil pressure needle on the dash stayed on low red and the oil light/beep started up. I'm still waiting the oil filter to arrive but could this be an indication of something additional? I wasn't able to replicate the alarm after.
Don S
Go to Napa and get a standard Chevy oil filter and see what happens.
bvlmv
Hi Don,
I was finally able to change the oil filter and I'm getting a low oil pressure from the start. I had a spare oil pressure sender guage and swapped it out to test but no luck.
Here is a video of what I'm experiencing. Happy 4th!
Don S
Go to an automotive parts store and get a mechanical oil pressure gauge and temporarily replace the gauge sender with the mechanical gauge and see what it shows.
Don S
No you don't want a compression tester. The oil pressure test kit will work fine. even a dash gage with a short tube will work, doesn't have to be fancy, it's only going to get used one time. (Hopefully)
bvlmv
Got caught up with the festivities yesterday but here is the result of putting a mechanical oil pressure guage.
bvlmv
I just noticed this loose cable dangling right above the oil filter and it looks like a bolt is alsomissing. Could this be the cause? I don't have any oil leaking in the bilge
