The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Hi
I have a 1999 150 Johnson. I have a remote oil tank for the engine oil. It is hard to see but I can't see any electric connections on the remote oil tank. I would just like to locate the low oil level switch.
thanks in advance Rod
The low oil sender is definately in the oil reservoir.Whether yours is wired in is another matter.Should be two wires leading from the reservoir to a location under the engine cover.Do you know if your engines vro has been disabled or is still in service?
Hi
I just bought the boat. The previous owner took it out with me. He said when the light comes on he has to add oil in the remote tank. The red lights come on in the tach for the system check then go out one at a time when starting. I will take a better look tomorrow.
Thanks Rod
As a rule ,I never allowed mine to drop below the half way mark bearing in mind the varying angle of the reservoir while boating.3/4 level is even better.A quart between adds to maintain this level range is sufficient.
I can't see the level on my tank. It is even hard to see the tank. There is a long flexable tube that runs to a fill cap higher up on the boat. All I have to
let me know is the light and alarm.
Rod
Rod
That sucks !!! You mean that you can not see it from anywhere ??
I have full vision of mine by moving a cover. I dont know if my low level signal works as it never gets below half full before I fill it up again.
