low oil alarm comes on and engine bogs out.
mx3811
pump the oil ball and the alarm goes off. Starts right back up will runn ok as long as someone keeps pumping. Had vro pump tested and was told it was pushing out proper pressure.
papaterk
Re: low oil alarm comes on and engine bogs out.
Start at the oil tank and check every hose connection and the hose itself. If it is old, replace it. Don't use worm clamps on anything. Spring clamps or special made zip ties (from boat shop)
Pop
