I have a '77 85HP Evinrude. I did a compression test and I have one cylinder that is very low. Three of them are around 140psi and one is 45psi. Are the rings the only suspect or are there other things that can cause low compression? I just bought the boat and the motor does run. Any help or thoughts would be very appreciated.<br /><br /><br /><br />------------------<br />- Burke<br /><br />If I'm not working on the boat, I'm working on the Mustang.
