Re: low compression #'s
Cylinder walls rusted from sitting, and now the rings can't seal, leaking head gasket, valves not sealing the combustion chamber.<br /><br />If you have a 6 gallon tank, mix a heavy mix of Marvel Mystery oil and gas, get out on the water and run the engine, then do another compression check. I have had reasonable luck doing this, but there is no prefect way to get the compression up if the rings can't seal.
