Low Compression in 1999 25hp mercury
salty jack
my well maintained ,low hours {65} 25 hp Merc started to idle rough,took it to merc mechanic who tested compression ,only 65psi in top and 55psi in bottom,what can the problem be. motor regularly serviced,never overheated.Suggestions please, motor still runs well at speed.
roscoe
Re: Low Compression in 1999 25hp mercury
It could be the mechanic doesn't know how to properly check the compression, or is trying to make the engine look bad so he can make money off of you.<br /><br />You may just have a carb problem or an ignition problem.<br /><br />I would get a second mechanic to look at it.
The Marine Doctor
With numbers like that I would suspect that maybe it was run without oil, overheated or run lean on the top end.<br /><br />But it is always best to get a second opinion.<br /><br />TMD
werdna
Agreed. Where abouts in Aus are you? if you're in Perth i can reccommend to you a fantasic mechanic who's been doing all of our motors for as long as i can remember. email me wrighta@vesta.curtin.edu.au if you like
salty jack
Thanks guys,I am in Cairns at the moment on a fishing safari amonst the big barra at the top end,so as you can see they{mechanics} have really got me by the short and Curliesand I have been really particular about fuel and oil
salty jack
Just thought of something, had to remove motor from the boat and travel 800k's over very rugged terrain with the motor lashed down in the bottom of the boat, would that have stuffed anything up?
The Marine Doctor
Those engines are tough...some bouncing around would probebly not hurt it. You could though check for loose wires.<br /><br />TMD
