I have a 1979 Mercury Blueband 50 HP. The previous owner hadn't run it for quite a few years. I got it running, hard starting even after changing plugs. Took it out on the lake. Ran well except for a little rough idling. Ran into a water pumping issue, got it solved with a new impellar. Now for the bad news. Did a compression check on it. #s 1,2 and 4 cylinders show 130, #3 shows 40. A local shop did the check and the owner told me it was in that cylinder, rings or piston, and not a valve issue by the way it acted when he cranked it over and had it running. Left with an under $1200 labor estimate plus whatever the parts would be, something I'm not sure I can afford.
Are there any preliminary measures to take before spending that kind of money? Would decarbing be worth a first effort? Any other suggestions?
Thanks a lot for your time responding.
Marty
Marty
