Randy stoner
- Aug 20, 2002
- 78
I had a brand new remanufactured 3.0 cobra (chev) engine installed last September in my 17 foot sunbird bow rider and its never been as good as the 130 i had previously. This one is a 140. I have had issues with it since day one and currently there is not 15 hours running time on it not including the intial 5 hour breakin the marina did initially. I just cant seem to get the revs high where they shoudl be. At best i might hit 3900 rpm and the motor is rated for 4850 rpms. I have tried different props, pitches diameters etc without any noticeable difference. Up to 3/4 throttle is seems ok but the last 1/4 has nothing, no difference in motor sound or rpms. Its as if there is nothing there except this long drawn out sound that sounds like a cow mooing. I have checked the linkage and it is correct as well and there is fuel squirting down the throats. Today i took a compression check in each cylinder. 108, 110,100 and 104 psi in cylinders 1 to 4 respectively. Im not happy. This is an out of the box crate rebuild from a reputable remanufacturing company. I installed the compression tester in earch hole. Started the engine up; blipped the throttle then shut it down and went on to the next. Idealy you want to have the throttle wide open when testing but i cant roll the motor over with the key with the throttle wide open as it will not signal the started if not in neutral. I ve done compression tests on other engines, outbord and inboards and never seen such low numbers. Im contacting the marina that installed this on Monday. Somthing is wrong here and ive wasted most of the summer waiting for them to decide what to do.
randy
randy
