Re: Low battery voltage
12.25 would mean that the battery is only at a 50% state of full charge, but keep in mind a volt meter is not a good indicator of battery condition. You need a load tester to tell that. Does your battery have good cranking power at this reading, or are you just concerned about this voltage reading. Your engine has a 9 amp, fully regulated system, How much equipment are you drawing off the battery? I would do a running test with an amp meter to see what is really going on. You will want a service manual to guide you through these test's. You want to be carefull doing a running test with an amp meter. If you short out a lead, you will have a charging problem.
