Hi all, I have pulled the manual ans done some pretty extensive Google searches to find what the low and high pressure readings should be on my Dometic Marine Air Systems VCD12K, 205 31157 circa 2007.
From my searches, it appears there is information that low should be 70psi and some other information found that high should generally be 250 or so.
I'm reading 50 from the blue discharge valve right now after putting in one can.
I probably have a leak, but knowing what the pressures are supposed to be will help me diagnose the issue.
Thanks!
Thanks!
