louisville bent prop shaft repair
maddog2112
I hit a rock in shallow water on my tahoe Q6. I thought I had just destroyed my prop, but when I replaced it with a new one, I can see a slight woblle when spinning the prop by hand. I confirmed the bent shaft while out on the water with the new prop. I can feel the vibration at low speeds. I would say the bend might be an eighth of an inch or so. No leakage at all yet. Does anyone know of anyone in the Louisville ky area who uses the Quickstraight hydraulic system, that can straighten the shaft on the boat? I would rather not file a claim with progressive, since I`ve only been with them 8 mos or so.
maddog2112
Re: louisville bent prop shaft repair
If noone has seen this tool, you can google Quickstraight. I would buy one myself if they werent 900.00 bucks. I`m tempted to buy one of these things and start my own business.:p
Ayuh,... What kinda motor/ drive is a Q6,.?.?.?.? Never heard of it....
Boats don't have a propshaft...
four winns 214
Call Tucker's Landing Boat Propeller Service: 812-283-4500
They're located near all the commercial development off Veteran's Parkway in Southern Indiana off I-65. They may not work on your particular problem, but could probably point you to someone local who can. By the way, they do great prop work. Don't ask me how I know!
maddog2112
Sorry, the Q6 is a tahoe Q6 5.0 merc alpha one. I believe the the prop has a shaft.
smokeonthewater
x2 on tucker..... real good guy..... if he can't do it I bet he will know who can.... Also check with kentuckiana yacht sales in jeffersonville 812 282 7579.... great folks there too RJ (parts) has always taken care of me I don't know if they can straighten your shaft or not but they'll likely know who can
picklenjim
An eighth inch would be one heck of a bend. If it's bent that much you would probably be better off replacing it. Having them straightened isn't cheap.
