Loud rattling 'tin can' sound - starboard 5.7L VP
tzylka88
I have a 2009 Cobalt 303 w/ twin 5.7L VPs. When I get above 4500 rpms the starboard engine will make this intermittent loud rattling 'tin can' sound. It literally sounds like a large tin can rattling around the engine compartment. When I continue to throttle up the sound happens more often and more consistently. Performance is not affected, water temp is fine, oil pressure fine. Under 4500 rpms - no sound. Any ideas appreciated!
Todd
Don S
Re: Loud rattling 'tin can' sound - starboard 5.7L VP
You better get it fixed before you burn holes in the pistons. Sounds like detonation, or pre ignition.
How about some engine information, model number, serial number.
tzylka88
2009 - Twin 5.7L GXi DP; 4012220414 or ...415 (not sure which is starboard motor).
Don S
Might want to recheck your numbers. Those serial numbers come back as a 5.0L , not 5.7. and they are from 2006/7
tzylka88
4012250415 & 4012250414. I added and extra '2' by mistake.
Don S
That's for a 5.7OSi-300-J engine. Can't really help you with that one, no information on the EFI system for that new an engine.
