Franco_boater
- Nov 2, 2021
- 112
Hello
I wanted to put my boat into the water after winter.
Boat runs great with new impeller and exhaust gaskets BUT…
Trim gauge doesn’t work and water temp…
Before winterisation everything was fine…
How to check if the sensor is ok or check the signal to the gauges ?? Thank You for help
When I turn the key to the ignition position, all other gauges wake up but water temp and trim sensor does not…
