Hi all,<br />I have an 18' Astro Fish/Ski, 1995 Force 120.<br />Took the boys sking today. After about an hour of fun and very smooth running, I lost most of the power from the motor. I usually turn about 4800 RPM at WOT and get about 45 mph with that. Went to accelerate, pushed the throttle to full forward and the engine would not spin past about 2K rpm. Tilted the motor up to check to see if I can tangled the prop on something, but it was clean. <br />You also need to know that last month I had the stator and #3 coil changed. She has run great the past two times in the water since then. <br />Where and what should I start trouble shooting?<br />After looking at previous posts and using the search function, I am leaning towards checking the fuel system. I'll start with the inline filter. Also read about the fuel pump diaphram being a problem for some. Any advise on direction is greatly appreciated. Thanks in advance.
