Re: Lost key evinrude 115
you can start it if you disconnect the large red harness connection,and jump directly to the starter,but,you wont be able to shut it down unless you use the manual choke,its a dangerous ,thing to do ,but can be done if necessary,as suggested look for that number,its likely a 2 digit number on the side of the slot key goes in,unfortunatly the numbers often wear off,magnifying glass may help
