I have a 2000 Mercruiser 5.7 litre MPI 300 HP sitting in a Malibu 20.5 Sport Cuddy. The leg is the Bravo 3 with 26 pitch stainless steel props.<br />The engine has 240 hours into it.<br /><br />I've owner the boat since new & have maintained it very well.<br />Top speed was bragged to be 65 MPH although the most I've ever got was 64. 60 MPH was always a piece of cake even with 4 people in it. RPM was usually around 4800 if memory serves me right.<br /><br />The problem lies in the top speed. I don't know exactly when I noticed it but definetly in the past month the boat will not exceed 55 MPH & 4400 RPM. The engine does not miss or sputter at this point, just no go.<br /><br />All other areas of performance seem very normal. Good out of the hole, same RPM at 30MPH as it always was. No engine misses or hesitations. <br />Engine is fresh water cooled & runs usually around 160 degrees.<br /><br />Maintainence I've performed.<br /><br />LOF every end of season.<br />Just changed the fuel/water separator. This is the 3 time since new.<br />Leg serviced this spring, 3rd time since new.<br />Checked two spark plugs today & both appear to be fine, but at 240 hours they should be.<br /><br />First the hull. Excellent shape & not stored in the water. <br />Waxed twice per year including the hull.<br />Props have a few tiny knicks in them. No different since 2 years ago.<br /><br />My thoughts along with my techs thoughts was a fuel problem. ie: plugged fuel/water separator.<br />Possibly a fuel pump.<br />He did a pressure test & it's sitting at 34psi. <br />The specs in a car are about 65psi. I phoned a marine shop here & he thought 34 was about right for the boat though.<br /><br />Any help of course is what I'm looking for & all help is greatly appreciated..<br /><br />Thanks
