levittownnick
- Jul 2, 2003
- 789
Johnson '97 150 HP, J150EXEUE. Starts easily but acceleration at higher rpm suffering and does not get above 4300 rpm. Checked compression and found same readings as in 2007 (10 years ago). Re-did timing and no change in settings or performance. Last season it ran normal. When It was winterized, I noticed a leak caused by a crack in the electric choke, so that part was replaced, also, failure of the fuel filter cartridge over the winter (the Bowl FELL OFF!) caused me to change to a different spin-on filter. The linkage all looks OK.
Do you have any suggestions?
