Re: Loss of spark under load
FAJSAM.... It would be a good idea to find another mechanic to obtain a second opinion. The rectifier is simply a component that converts the AC voltage generated by the alternator to DC voltage so that it can be used to charge the battery. It has nothing to do with the ignition system other than keeping the battery charged. Bypassing the rectifier would eliminate the charging system, causing the battery to discharge.<br /><br />From what I gather, the engine starts and runs okay at a slow rpm, even in gear. However, when you attempt to give the engine throttle, you hit a point where the engine simply wants to die out.<br /><br />If this is the case, either the throttle butterfly is opening too soon, the carburetor is fouled, or the timing is set wrong. The usual cause is a fouled carburetor.<br /><br />I assume you've checked the compression and spark? Should be approximately 100+ psi and even on all cylinders (compression)), and the spark (with plugs out) should jump a 1/4" gap with a strong blue lightning like flame on all cylinders. Keep us informed.
