harrydohnert
- Jun 12, 2005
- 15
I have seen this issue all over the posts, but I have no really found any solutions. I have an issue that when I run my boat for a while, I start to lose power, until the engine will eventually conk out. If I turn the boat off and let it sit for a while, I can usually get going again, but the problem will happen more quickly the next time. If I change the main fuel filter. the boat will run fine for another week or two (A few hours running time.) I have changed the carburator strainer. I just got a tune up on the engine. I am pretty sure its some sort of fuel delivery problem, but I can not narrow it down, and it is driving me nuts. Changing the fuel filter is not that big of a deal, and its cheap, but I am wondering if the problem will go away by itself, or does something need to be done. A mechanic I explained the situatuin to, quickly replied, "You need to have your carb rebuilt." If thats the issue, I have no problem doing it.. I just do not want to rebuild my carb, and then its something else. I have a Sea Ray Weekender 230 (1986) 8 Cyl, 230 HP.. Any advise would be greatly appreciated.
