Dersu Uzala
- Aug 3, 2009
- 9
My 1988 Evinrude 88 spl ran fine for the first 20 minutes of a water skiing session. We switched skiers (both skiers were under 120 lbs) and the next time that I tried to throttle up, the engine was super sluggish and could only produce enough rpms to get up to about 11 mph. I dropped the passengers at the pier and tried to power up with just me in the boat. It was still very sluggish, but it slowly got up enough rpms to go 28 mph. Normally, the top end is around 34-35 mph. The motor starts fine as long as I give it a little throttle. It runs fine as long as I keep the throttle slightly above a low idle, but it does give off excessive exhaust. I ran carb cleaner spray through the carb, but it did not make any difference. When the motor is trying to build up rpms, it sounds like it's on the verge of accelerating, it just quite doesn't have the power to get up and go. Any thoughts on diagnosing the problem?
