spirit85woes
- Apr 9, 2005
- 7
Hello all, first time forum user here, but I have been searching for quite some time, hoping to find an answer.<br /><br />I have a 79 Spirit (made by Suzuki) 85 horse outboard. Now, this boat was in storage for about 20 years, I took the carbs off, cleaned em good, made sure the float and needle were decent in each carb, and hooked the linkage back up. I also blew out the fuel lines, cleaned the tank, replaced the squeeze bulb, took apart fuel pump cleaned, and made sure no diaphram cracks or anything, replaced lower end unit fluid and such.<br /><br />The problem, It starts, and idles pretty good. I give it the hammer, and it comes right up and planes out nice for about 3 minutes, then it seems to drop about 3000 RPMS and just struggles to stay running. It seems to be getting fuel, I squeezed the bulb and that didnt make any difference. No Carb overflow leakage, and it doesnt seem to be sucking air. I made sure the tank vent was open, still doing this.<br /><br />Water is squirting out the port in the lower unit, and the cylinder walls seem a little warm to the touch, but not extremly hot or anything. If I shut the boat off a few minutes, it will plane out again and high speed, but then after trimming it up a hair and getting a good plane, she will dog out. All 3 plugs are getting good spark when I checked at an idle.<br /><br />Top and bottom carb lean/rich adjustment screws were 2 and 1/2 turns out, and the middle carb was 5 turns out. I set all carbs at the same setting 2 and 1/2 turns out. Still dogs out.<br /><br />Last night It got a little dark out, and a bit cooler, and the boat ran like a banshee, no dogging out. Took it out today, same deal... runs good for a few minutes on plane at high speed, then just dogs out completely until I turn it off a few minutes. <br /><br />I dont have an instruction manual for this motor, and cant find much on the net. Is it possible that the 3 coils need to be replaced? or is it possible this motor is overheating, does it have a thermostat? can the motor impeller be taking in water, but not circulating it to the block?<br /><br />I could have swore it was a fuel thing, but I have had these carbs apart a few times to clean them completely. They are Mikuni carbs, but I cannot find a refrence number on them anywhere, or any Spirit info to figure out which model carb these are, and where to find a rebuild kit.<br /><br />If you have any experience with this motor, or have a general idea of what my problem might be, please respond.<br /><br />Thanks in advance, you guys and gals are great!<br /><br />Tim
