phoenix_fisher
- Feb 19, 2011
- 5
I just purchased a 1988 Bayliner with an 85 horse Force outboard. Had a mechanic check out the motor prior to purchase. He indicated that it needed a new impellar because it was running a little hot. It also needed a new lower unit gear gasket set. Since the purchase, 2 weeks ago, I got into the a shop and had repaired. The gear oil leak has not reappeared since the repair and the motor appears to be getting enough water when it runs. So......I took it to the lake yeaterday and ran it for about 5 hours. Off and on because we were fishing. Motor ran outstanding from the launch until about 3 hour into it. It had a tough time restarting after fishing but it always did start. Then on our way back to the launch, I started it and could not get it past 2000 rpms. No back fires, no smoking. IT was act like it was going to plane out then was bogg down and die.
