On our 1992 Bayliner Capri 120 L Drive, we are experiencing a loss of power after about 2 hours of play. Everything seems ok the next day until you run for aprox 2 hours. Fuel mix is correct, fuel delivery seems to be ok, and carbs have been gone through.<br /><br />Another problem. There seems to be a intermittant idle problem. Sometime it will do fine while other times it will go dead when you put it into gear. I have to use the fast idle alot. <br /><br />Another Problem. What would cause the throttle to be stiff when pulling back to neutral?<br /><br />Thanks<br />Chris
