loss of power 1986 175 black max
dnewell
I put 1 new power pack on and it still won't go over 1800 rpm. It idles and starts fine. Has any one had a similar problem? thanks, Dale
Kenny Bush
Re: loss of power 1986 175 black max
How is your compression? What made you change a control box? Need more data. I want to make sure your block is good before we move to fuel and electrical. :D :confused: :cool:
dnewell
compression is okay. The top left cyclinder didn't have spark. Mechanic put 1 power pack on. It didn't help. He know says it know needs a stator. Thanks, dale
CU2NITE
He should of check the stator and trigger before he suspected the pack. There is no real test for the pack. You may want to run this past him. Good luck and let us know.<br />CU
have him check how many volts your stator is putting out mine did the same thing was only putting out half as much as it should replaced stator and it screams now!!!
