Jim Robbins
- Jun 15, 2005
- 85
1973 Starcraft 18' Holiday, 140 I/O, I bought this boat 6 weeks ago, so I'm working out the bugs. I did have the nav. lights, horn, blower & bilge pump working fine. Been on the water 7 - 8 trips, one night I pull on the lights Nothing
No lights,horn,pump,blower I guess they are all together, so with a flashlight I look into the birds nest of wires and find a fuse holder and it has a blown 20 amp. fuse, I replaced and all is working. Two trips later the fuse blows again, I put in a new one and it works for a while,
*then out go the lights and everything is not working
BUT the 20 amp fuse is good( I try a 2nd fuse/ nothing) ? There have been a lot of mods over the years, and I have to remove wires that are not in use anymore (remove the birds nest)
Where do I start, any advise? Should there be 4
seperate lines?
Do these accs. hook up to the same spot as the motor starting wires? thanks
seperate lines?
