Re: Losing Power
When you start to lose power, push your key in (prime the motor), if it "picks up" you likely have a fuel delivery problem. Fuel pump diaphragm, air leak in fuel hose from tank to motor or on motor. If it "falls down" when you push in the key, it doesn't want any more fuel. Be aware you're flooding the motor with procedure, and it can make it very hard to resart, don't hold the key in too long.
