losing power after few hours J110hp
I have a 1988 johnson 110hp. The motor has run great for the last year, but the last four times I have taken it out it started to lose power after a while. I idle down and it appears to run well. I pump the ball and it is tight. I replaced the bulb, gas, and gas filter(no help). I am thinking that I may have a bad stator or coil pack? Is there a way to check either with a ohm meter? The local boat supply house said that it sound like a high speed coil in the stator? Thanks in advance for any and all time spent troubleshooting?
