Loose the coupler??? Don S
kmuir2108
Hi Don! While going through the threads for ideas I came across a post from you that states "Loose the coupler and you loose the raw water pump in the drive". My coupler burned out last year. When I replaced it over the winter I have not touched the water pump. Should I rebuild this also? It's a Mercruiser 120 1984.
bomar76
Re: Loose the coupler??? Don S
Well, I know the answer, but since I am not Don S. I guess I will have to keep it to myself....
kmuir2108
Let me clarify! If ANYONE knows the answer, please advise! Sorry for the confusion!
freddyray21
impeller's need to be changed every couple of year regardless. bought a motor (outboard) the other day. asked him how long since it's been changed and he said never. I asked him how long has he owned it he said 13 years. I will be changed.
Fishermark
The reason you lose the water pump when you lose the coupler is because with the coupler stripped, the outdrive stops turning. When the outdrive stops turning, the pump stops pumping. It doesn't damage the pump, it just doesn't work.
Having said that... if it has been awhile since the impeller has been changed, then yes, it needs to be changed too.
