Loose hoses
bhoneycutt
So I wanted to replace the fuel hoses and stuff while I was rebuilding my fuel pump because there was some cracking and one of the hoses looked to be leaking. Is there a trick to getting the hoses back on tight? They were on with zip ties before but i just cant get new zip ties on there good enough and they are also in hard to get places. Is there a trick to getting them on there tight?
jimg984
Re: Loose hoses
can use min clamps just a small verison of hose clamp auto supply,,, walmart
Yepblaze
Re: Loose hoses
Use a cable tie gun, or tool.
By the way, the plastic zip ties used by Mercury dealers are a bit different than your run of the mill electrical counterparts.
j_martin
Re: Loose hoses
The difference is that the fuel line ties are made so that they form a perfect circle and evenly clamp the line. Electrical ties will pinch the line, and sometimes even pinch in a leak at the barb.
hope it helps
John
