Hello All <br />I have a 1972 Evinrude 50hp outboard<br />(Model# 50273 C) (Serial# E01322) It has started to show a power drop on top end. It will idle OK but when you goto to full throttle it will run fine for 30 sec. and then it will fall off plane and drop RPM dramatically, if you throttle back it will run fine but if you leave it at full throttle it will not stall but it's unable to maintain planning speed and it will act like you are going from full throttle to idle back and forth very fast. At first I thought it was fuel related so I put a new fuel hose and a new fuel pump on but nothing changed so after reading a few post I decided to check the coils on the stator. I can wiggle 3 of the 6 on the stator under the flywheel. So Does any one know if the coils can be tested without removing the flywheel and if it test OK can it be tightened or is it a part you must replace and how much does a stator cost to repair? Also is it more likely the stator or a fuel related problem? It has good compression and good spark when I try it in the driveway. I think I will still go through the carbs just because it has not been done in a while. Thanks in advance for any help<br />Musky14
