jim j geezer
- May 16, 2012
- 189
I have a '59ish 7.5 Scott McCulloch as a parts motor. The lower unit is shot, but the top end seems okay. Got to thinking of using it for... something. It was missing the recoil assembly, so ordered one off ebay. Happened to see an ad for a carb off a 12 / 14.1 HP Scott, and rolled the dice. The carb arrived today. Looked it over and compared it with the original. It'll bolt right up, and the butterfly linkages match.
The original is a Carter, model "N".
The 'new' one is a Tillotson.
My current problem is "carb theory".
The original has an inlet to the venturi that's 1-1/16".
The 'new' one has an inlet to the venturi that's 7/8". <--noticeably smaller
Both outlets from the venturi are the same size @ 13/16"
I've been under the impression that a carb rated at a higher HP will have a larger inlet - to more compress and accelerate the airflow.
Given that the hi-speed jet might be larger on the higher HP carb, am I missing anything else?
My head hurts...
My head hurts...
