dmoriarty51
- May 4, 2010
- 305
when i look it up here by motor and pitch i dont get anything close in size to whats on now.
boat is a 1995 crestliner pro am 1650sc, it has a johnson 70 on it. the prop according to the info stamped on the hub is #389948 13 3/8 x 17
if i look here on iboats for a replacement i get nothing in a 13 inch diameter at all when looking at 17 pitch so perhaps it doesnt belong on this motor?
it seemed to perform ok, i believe i was maxed out near 5000k rpm but cant recall for certain. i plan to run it again with this prop and double check now that i have replaced some worn out spark plugs and and dirty fuel filter.
my average load would be between 5-600lbs what should i be using for a prop? im looking at replacing due to it being rather beat up.
im not chasing 1-2 mph i got the rig on the cheap to learn whether i really want to own a boat or not and its uses include cruising maybe a tube and prolly some fishing
