Hi
Montezumasdaddy
I currently have "1996 Bayliner 1700 LS BR" (example seen in:
https://www.youtube.com/watch?v=2_JoYnQpo7E ) . Had it for 3 years and pumped lots of money into its factory Force 120 engine. This month, I'm replacing its broken Force 120 engine (which is a 90 HP at prop) with a 1996 Johnson 115 engine. Blow the Force 120 head gasket 2 times last season. Mostly likely from under sized engine for our water sports / tubing adventures.
During my ownership, I'd recommend:
- Remove its sloppy tilt steering shaft and replace with solid steering shaft re: Telflex Rack & Pinion NFB / 15 ft.
- Dump its Force engine and go with different engine - with higher HP and higher reliability (like Yamaha or Johnson brands)
- Keep boat off the water when not being used. re: On a trailer or on a boat lift.
- Keep boat covered (to keep rain out of it). We "double tarp" our boat - even during summer months.
- install Water / Fuel Separator - to keep its fuel clean.
- Install Tabs on its rear lower transom area - to lift its rear (to get on plane much faster).
- If into water sports, get 4-blade x 17' aluminum prop. If into cruising, get 3 blade 19' aluminum prop.
- dump its factory square driver's seat and install a captain's swivel chair seat.
- Install keel guard / rubber strip (for frontal beach landings)
- Install guides on its trailer.
- Install spare tire on its trailer.
- If needed, install brakes (full electric brakes) on its trailer. Especially if your Tow Vehicle has weak factory brakes.
Bayliner is considered entry level (which means lower quality build). If doing some "around the lake" touring, some fishing and tubing with 6 or less people, the 17 ft model is good. Especially when little kids can sit in the front bow area.
I like our 17ft Bayliner so much, we decided to install better engine. re:
http://i178.photobucket.com/albums/w...s/IMG_0001.jpg
Would I buy again for 6-12 times "around the lake" each year? Sure. But... I would buy an 4-stroke V6 inboard for long distance touring and/or heavy water sports. And for larger size lakes, I'd go with 19 ft + size - which has a smoother ride and higher people capacity as well. My next boat (after our 1996 Bayliner needs replacing) will be 19+ feet with V6 4.3 engine.
Hope this helps.
