Is it possible it to add a water temperature gauge to the cluster? Does any additional wiring need to be added? Been trying to search online thanks in advance for any responses
There is no Termp sender on the engine, only a switch. Therefore if you want to add a temp gauge it will have to be an aftermarket gauge/sender combo and run you own wire up to the dash.
