Looking on advice about connecting my 1983 7.5hp mercury to cable pulley steering
davhen2311
I have a speedboat with old cable pulley steering and a 1983 7.5hp mercury outboard I would like to hook up to it but not sure what brackets and other parts I would need to get it set up. also I would like to wire a stop switch from beside the steering wheel to the stop switch in the engine. I dont need throttle controls just the parts to connect the steering :)
you will need the same conversion bracket to go from tiller to steering. you can wire a switch to the same two points that the cowl mounted stop switch is connected to.
