Looking for some comments!
rdnk_4_lf
Re: Looking for some comments!
well it depends on the make and model and use your own judgment if you think is a good deal buy it if you dont then just go buy something else i know of alot of boats i could buy for 3900 but thats just my opinion thanks, nick :rolleyes:
btowndms
I understand what you are saying! I am just looking to see if anyone has experience with a late 80's Rinker and things to look for when shopping for a used boat.
rdnk_4_lf
well i mean i dont any need for a ski boat as high as gas is it just seems like a waste if i was looking to buy a new boat i would boy a good fish/ski so you can do a little of both but as i said thats just my opinion
tashasdaddy
i never buy a boat that i can't get a test run, unless it is a project boat. you need to know the maintenance that has been done. it is due for Bellows, Manifolds, outdrive pulled and serviced. when was the last time it was serviced, and the engine started.
Buying a boat
1st you need to decide what you want to use it for, fishing, cruising, or water sports.
2nd how many people adults, children you want on board of the average outing.
3rd outboard, inboard-outboard, or inboard power plant.
4th Budget, what you want to pay, and what you are willing to pay, when you find
Exactly what you want.
You can hire a marine surveyor, to inspect the boat, or you can do it yourself.
You are mainly looking for soft spots in the deck, transom, cracks, all signs of a rotten, under frame. You walk all over the deck, that a mallot, or hammer with wooden handle, using handle, tap all over the transom, a shape rap is good solid base, a thud, is questionable base.
The motor should be clean, no spots where the paint is discolored, or pealing from heat, having run hot. (This part for outboard motors Compression should be atleast 100psi, and within 10% of each other,)
Spark on all cylinders, good pee stream, check lower unit for water in oil.
The overall condition of the boat will tell you a lot, as to how it has been maintained.
A 30 year old boat motor combo, may be in better condition, than a 3 year old.
tmh
IF that bots is in as good of condition as it looks it's a STEAL at $3900. Yeah, lots of boats can be had for that amount, but how many still have excellent looking vinyl, great exterior and have been garage kept? Believe me, if it's the style you want and the engine checks out OK then it's a great buy.
Make certain there are no soft spots on the floor, knock around the transom to make sure it's solid, etc.
A test ride will go a long ways to telling you how it runs. After 2 years it may need some maint. to get it ready for a test, which needs to be done anyhow.
ezmobee
I agree with tmh. I think if it checks out that's a steal. You can arrange the test drive as a condition of the sale. As in, you agree to buy the boat at that price following a successful test drive. Protects you from buying a boat that doesn't run or has issues and proves to him you aren't just a tire kicker. I know I'd be happy to allow a test drive to the eventual buyer (unless I was hiding something!!).
rdnk_4_lf
hey that looks rele good i got 1 like that layin out here in the back yard with major issues the power packs the stator all of the firing system is bad good lower unit tho
NSBCraig
Umm.. yeah what tashasdaddy said
Dakota47
Looks Great, i have the same boat
