Looking for pull switch
Davetowz
Has anyone seen and have a source for a momentary 12v switch that I can use in the overhead with a pull lanyard for the horns? Thanks in advance.
look up anti two-block switches. most have both a no and nc contact.
or you can go with a lever-actuated limit switch.
Davetowz
The ATB would work, that is a pricey switch! Lever limit switch is an idea. I will keep looking at the catalog listings. I am sure there has to be a simple relatively inexpensive switch out there somewhere.
Davetowz
Cole Hersee 9109 is the answer. Google it. Low cost. I forgot to update this when I found it. Hopefully this will help someone else someday.
