Looking for parts for a 9.8 Mercury Outboard
Gerald O
I am looking for a carburator, and two throttle cables for my 9.8 Mercury Outboard. serial # is 7169209. I hope someone can help, as I would like to have this up and running by spring. I will buy the top part of the handle with the cables if you have them from the elbow with the two screws and cables included.
emckelvy
Re: Looking for parts for a 9.8 Mercury Outboard
Check on eBay, lotsa parts there for 7.5 & 9.8 Mercs.
BTW those cables are still available from your local Merc dlr, P/N 86210 at $23.37 each, or $18.93 ea at boats.net:
http://www.boats.net/parts/detail/merc/M-86210.html
Unless you can find perfect used ones, that might be the best way to go. You'll get nice, smooth throttle operation with new cables.
HTH............ed
Fun Times
Merc has two carbs listed for your engine, So it looks like you will need to know what carb you have, So you will need to look at the carb and see if it is stamped with one of the names or numbers below. By the way those part numbers are no longer available from merc. So you might want to check into this place to see if they do outboards carbs. [Not sure] http://www.flyingfishcarburetors.com/pictureid.htm
MERCURY - (9.8 H.P. (1980))
Serial No: 07169209 Model No: 1010220
Part # 7909 CARBURETOR ASSEMBLY, COMPLETE - (MERC 9.8)(TILLOTSON STAMPED 1364-7909)
CARBURETOR ASSEMBLY (MERC 9.8)(WALBRO STAMPED WMB-1 OR WMB- Is part # 8782A3 CARBURETOR ASSEMBLY, COMPLETE -
