looking for part #'s
bigtimehustler
need to replace water pump and possible thermostart on 2002 Honda BF90A2LRTA
can anyone provide part #'s and where to order from, i'm having a hard time locating
ahicks
https://www.iboats.com/shop/engine-p...aft-Parts.html
Honda's water pump "kit" for this engine has some parts I would not use, like the seals, and does not include a parts I use frequently (like #3, the liner). Point being, I generally order what I need after pulling the pump down.
Mod EDIT: You dont have to shop here at the generous sponsor of this free forum but refrain from posting links to their competition. Also refrain from attempting to defeat the auto-filter of competitors and/or their links by any means, including adding spaces to defest the filter.
Fun Times
Here is going to be your parts link for your engine model and the very last two on the bottom cover the impeller depended on what you may need to cover any unseen damage that could be there once you remove the lower unit gear housing, http://ww2.iboats.com/BF90A2/dm/view_id.1327463
Thermostat - 18-3630 - Sierra Or OEM # 19300-ZV5-043 Item # 10, http://ww2.iboats.com/Thermostat/dm/...iew_id.1327082
Water Pump Impeller Kit
Water Pump/Vertical Shaft
