Looking for a 1966 Evinrude 18 hp Fastwin part.
FlipnRip
I hope this is in the correct forum.
I have just come into a 1966 Evinrude 18 hp Fastwin included with an old 1970 aluminum V boat that I am going to refurbish. The motor seems to be in decent shape with one major exception the lower group part number 80, which is the swivel handle and tiller connection has a nasty crack in it. The part is not listed by any dealer as available new for replacement (imagine that) and so I am looking to either find a used replacement that is solid or discover if anyone has successfully repaired the cast aluminum and if so how?
I appreciate any help you can provide.
Thank you
F_R
Depending on exactly where it is cracked, yes it can be welded by a pro experienced in aluminum welding.
Mark Grant
Hi , I believe (check) that tiller parts from 18-28 hp OMC from 1965 to 1969 will be the same and should fit, OMC wasn't a company to waste leftover parts..lol. They're good solid motors.
From about 1958 to some 1984 motors , use the same bracket.----Should be easy to find.
