Re: Looking at a boat
I'm sure he wouldn't lie to you as a friend, but as stated he may not know any better. the statement on the impeller is a give away. Maintenance on this beast is gonna be suspect. Anyone who knows about boat care knows an impeller will take a set after sitting that long, and even if not they need replacing every couple years. SO who know what else he thinks is "OK"
For a grand you can't go wrong if the transom and stringers are ok and the engine runs, but it's gonna need work very shortly. You are gonna take it out and be back after after the first few outings with a post like "It ran great and then..."
The worst thing that a boat can do is sit. As soon as you start using it the gremlins will rear their heads
If you are up to the challenge go for it. But all the mechanical systems are going to be at risk. From rusty gimbel bearing to rusted light switch. Bad gas or gummed up carb. It's all there waiting for you..
And for the record, I am looking for just such a boat to use on lakes, so I am not saying don't do it, just be prepared for what awaits you. Most of us bought our first bought in very similar ways and we all went through the same thing when we did
One thing you will want to do is pull the risers and check the manifiold and riser conditions. There are too many sad stories of overheats and burning up engines right after newbies bought boats.
Good Luck!
M
