Re: Looking at a 20' Crestliner Nordic
Norseman is different than a Nordic. Nordic is a run about with walk thru window, closed bow and under deck storage. Has a soft top and back to back seats that lay down for sunbathing or sleaping. Nordic has more open room in back for fishing. Weight is 2800 lb or 1270kg.<br />Norseman 1980 is a hard top with front cabin, helm station behind cabin with pedistal seats. Has more cabin and less fishing room. Specs 21 ft 8 inches or 6.6 M, Max depth 82inches or 208CM, Max Beam 94 inches or 238CM, weight 3250 lb or 1474kg dry or no fuel, 34 gal gas tank or 128.7 liters, engines 140, 165, 170, 198, 185, 200. Hull is welded aluminum but stringers have some rivets. My nordic 20 after 22 years does not leak a drop but we do not pound it hard when it gets rough. With all the gear you listed and the exchange rate I think it is a great deal if that is type boat you are looking for. Aluminum boats are lighter so use less fuel and eaiser to trailer than glass. Since they are lighter also ride a little ruffer, go more over waves instead of thur. If keepped in salt water, check hull for saltwater corrosion and pits, check for dents or hooks in the bottom. Very low maintance boat if trailer and do not dock for long times in salt water.
