longshaft on a short transom
Re: longshaft on a short transom
It'll get you across the Pond,....... But Not Very Well........<br /><br />Handling,+ Any kind of Speed will be Impossible.......<br /><br />TOOOOOOOooo Much Lowerunit in the Water..........
JB
Outboard Non-repair topic
one more cast
I seen it done before by attaching a 2x6 to the top of the transom. It looked kind of unsafe but it was working and that was a 50 hp merc on a 14' aluminum Arkansas Traveler. I don't think its a good idea to try this however.
Wiggy
I've used a longshaft on a short transom and the things that are noticable are increased fuel usage and lower top speed. If you can live with this, it's no problem whatsoever.<br /><br />Though you have to jack up the boat on the trailer or you run the risk of either the prop or lower unit hitting the ground!
Solittle
I run a long shaft 9.9 on a short shaft transom in a 12' tinny with no problem. Looks kinda stupid sitting on the trailer but I don't care.
Thank you all for your advice! I am in the process of replacing the wood in my transom and will fill in the notch and reenfoce it with 1/4 inch aluminum.
